Total posts in this thread: 4
Previous Thread This topic has been viewed 3756 times and has 3 replies Next Thread
connomar
Duplicate Furniture
Hi, I have a problem with my personal Furniture Library, created using Furniture Library Editor 1.8 exe. All the objects I have imported are duplicates, whilst the base furniture only appears once. I've opened the file as a zip, and there is no sign of duplication there.
Any ideas?
Thanks
[Nov 30, 2012, 4:36:33 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: Duplicate Furniture
You probably save the library under an other file name before importing it again.
Go to the folder where SH3F files are stored and remove the oldest SH3F file:
- under Windows Vista / 7, this folder is C:\Users\user\AppData\Roaming\eTeks\Sweet Home 3D\furniture,
- under Windows XP and previous versions of Windows, this folder is C:\Documents and Settings\user\Application Data\eTeks\Sweet Home 3D\furniture,
- under Mac OS X, it's the subfolder Library/Application Support/eTeks/Sweet Home 3D/furniture of your user folder,
- under Linux and other Unix, it's the subfolder .eteks/sweethome3d/furniture of your user folder.
[Nov 30, 2012, 5:39:22 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
connomar
Brilliant, that's got rid of most of them. So when one imports a furniture library it is copied to your furniture folder, and the result is a concatenation of all the sf3f files in that folder.
Many thanks.
[Nov 30, 2012, 5:57:02 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
It's a little more complicated than that: objects in a SH3F file can have an ID, and only one object with a given ID can exist in the catalog.
But as the default version of the Furniture Library Editor can't let you edit the ID of each object, the behavior you noticed is actually right. smile
[Nov 30, 2012, 6:37:22 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
