Re: Starting a non square plan
As you probably have measures of the inner room (and not in the middle of the walls), you should rather use Hans' suggestion but using the Create rooms tool. Once your room is created, you can easily create the walls around it by double clicking in the room while using the Create walls tool.
[Jan 2, 2013, 11:45:03 AM]
[Link]
