Inserting objects at specified location in a building plan
Hi
Is there a way to insert (manually or programatically) new objects at a given position on a building plan ? I would like to be able to specify object position in cartezian coordonates (x,y,z) and to insert or remove this object in a building plan from my own program using an API.
Re: Inserting objects at specified location in a building plan
HomePieceOfFurniture instances can be moved with their setX, setY and setElevation methods. But why programming something you can already do with the existing user interface?
Then call the methods of HomePieceOfFurniture. The listeners that are already added to a piece will automatically update its location at screen if necessary.
