Re: Problem Starting Online Version
Do you get this error when you try to run the Online version at this page, or when you try to run your own version.
StNff, I don't understand why you report an issue with com.eteks.sweethome3d.applet.SweetHome3DViewer in a subject about the Online version (i.e. com.eteks.sweethome3d.applet.SweetHome3DApplet class). What are you trying to do?
Re: <font><font class=""> Re: Проблема Начиная Электронная версия </font></font>
I had JDK 7. Now I have JDK 5 (As in the instructions). Log compilation: D:\1>ant javaWebStart Buildfile: D:\1\build.xml
build: [mkdir] Created dir: D:\1\build\classes [javac] D:\1\build.xml:43: warning: 'includeantruntime' was not set, defaulting to build.sysclasspath=last; set to f alse for repeatable builds [javac] Compiling 2 source files to D:\1\build\classes [javac] D:\1\build.xml:46: warning: 'includeantruntime' was not set, defaulting to build.sysclasspath=last; set to f alse for repeatable builds [javac] Compiling 193 source files to D:\1\build\classes [javac] Note: Some input files use unchecked or unsafe operations. [javac] Note: Recompile with -Xlint:unchecked for details. [copy] Copying 261 files to D:\1\build\classes [zip] Building zip: D:\1\build\SweetHome3D.jar [delete] Deleting directory D:\1\build\classes
application: [zip] Building zip: D:\1\build\SweetHome3DStandalone.jar [move] Moving 1 file to D:\1\build
furniture: [zip] Building zip: D:\1\build\Furniture.jar
textures: [zip] Building zip: D:\1\build\Textures.jar
help: [zip] Building zip: D:\1\build\Help.jar
jogl-java3d: [zip] Building zip: D:\1\build\macosx\java3d-1.6\jogl-java3d.jar
java3dLibraries: [mkdir] Created dir: D:\1\deploy\lib\windows\i386 [zip] Building zip: D:\1\deploy\lib\windows\i386\java3d.jar [mkdir] Created dir: D:\1\deploy\lib\windows\x64 [zip] Building zip: D:\1\deploy\lib\windows\x64\java3d.jar [mkdir] Created dir: D:\1\deploy\lib\linux\i386 [zip] Building zip: D:\1\deploy\lib\linux\i386\java3d.jar [mkdir] Created dir: D:\1\deploy\lib\linux\x64 [zip] Building zip: D:\1\deploy\lib\linux\x64\java3d.jar [mkdir] Created dir: D:\1\deploy\lib\macosx [zip] Building zip: D:\1\deploy\lib\macosx\java3d.jar
javaWebStart: [mkdir] Created dir: D:\1\build\JNLP-INF [copy] Copying 1 file to D:\1\build\JNLP-INF [zip] Building zip: D:\1\deploy\lib\SweetHome3DJavaWebStartBootstrap.jar [zip] Building zip: D:\1\deploy\lib\SweetHome3D.jar [copy] Copying 6 files to D:\1\deploy\lib [delete] Deleting directory D:\1\build [input] Enter Passphrase for keystore: 1111 [signjar] Signing JAR: D:\1\deploy\lib\Loader3DS1_2u.jar to D:\1\deploy\lib\Loader3DS1_2u.jar as SweetHome3D [signjar] jarsigner error: java.lang.RuntimeException: keystore load: D:\1\keys.keytool (═х єфрхЄё эрщЄш єърчрээ√щ Їр щы)
Reading the README.TXT file coming with the source file would have given you the answer:
Note that the last part of the Ant targets javaWebStart, applet and viewer requires a passphrase for keystore to sign the deployed jars. For security reasons, the required file keys.keytool isn't provided with this source code. You'll have first to generate this file and choose a passphrase, with the following command run in the directory where you uncompressed this archive: keytool -genkey -keystore keys.keytool -alias SweetHome3D
