Re: Walls from prefabricated modules
If you use imported models, they behave as "furniture". So, they make look like a wall, but they do not behave like wall. Example: you cannot insert doors or windows in an imported wall segment. And you cannot give the inside of the imported wall segment a different colour or texture as the outside. That has to be done when you design the wall segments. On the other hand, you can place wall segments next to, and on top of each other, and you will not see the difference.
