Total posts in this thread: 2
Previous Thread This topic has been viewed 10125 times and has 1 reply Next Thread
Llewelyn
United Kingdom
Ocatgon v3
version 3, calculated correct dimensions for a regular octagon and changed the way I drew it slightly, the roof still isn't perfect but now the same roof section doesn't quite fit all of it smile Also got some better textures and did a bit more decorating, but ran out of inspiration for a couple of rooms. Ah, and I see I left one patio door in the wrong place. Can't select a wall section without moving it, as it covers the entire section on the plan.
[Mar 19, 2013, 7:47:18 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: Ocatgon v3
It's time to use the Select Object contextual menu to select the object where you right clicked in the plan. wink
[Mar 19, 2013, 8:47:09 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
