Total posts in this thread: 15
Posts: 15   Pages: 2   [ 1 2 | Next Page ]
Previous Thread This topic has been viewed 11875 times and has 14 replies Next Thread
binadnsh77
sad Using Sweet Home 3D in Eclipse
Hello everybody I am kinda new to this 3D concept and while surfing I came across this beautiful software. Actually I have a need to use some of the features of Sweet Home 3D in my project and as part of this I downloaded the source code and after reading the Read Me file I opened the source code project in Eclipse. I was able to compile and create jar file also, but on running the jar it is not showing anything. No error nothing.
Can anybody help me with this. This was kinda very very urgent request.
[Mar 22, 2013, 2:57:45 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: Using Sweet Home 3D in Eclipse
hat version do you use? On which system?
[Mar 22, 2013, 7:02:45 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
binadnsh77
Thanks Emmanuel for your quick response. On setting the VM arguments I was able to run it through eclipse on Linux and Windows2008, but I was not able to run it through eclipse on Windows 7 (32 bit). I am using SweetHome3D-3.7-src. Also I am not still not able to run the jar created through command line. Can you tell me how we can run it through command line. How do we pass the VM arguments on command line. I tried
java -jar SweetHome3D -Djava.ext.dirs=lib:lib/linux/i386
but it is showing an error---
Exception in thread "main" java.lang.reflect.InvocationTargetException
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
at java.lang.reflect.Method.invoke(Method.java:616)
at org.eclipse.jdt.internal.jarinjarloader.JarRsrcLoader.main(JarRsrcLoader.java:58)
Caused by: java.lang.UnsatisfiedLinkError: no j3dcore-ogl in java.library.path
at java.lang.ClassLoader.loadLibrary(ClassLoader.java:1681)
at java.lang.Runtime.loadLibrary0(Runtime.java:840)
at java.lang.System.loadLibrary(System.java:1047)
at javax.media.j3d.NativePipeline$1.run(NativePipeline.java:231)
at java.security.AccessController.doPrivileged(Native Method)
at javax.media.j3d.NativePipeline.loadLibrary(NativePipeline.java:200)
at javax.media.j3d.NativePipeline.loadLibraries(NativePipeline.java:157)
at javax.media.j3d.MasterControl.loadLibraries(MasterControl.java:987)
at javax.media.j3d.VirtualUniverse.<clinit>(VirtualUniverse.java:299)
at javax.media.j3d.GraphicsConfigTemplate3D.getBestConfiguration(GraphicsConfigTemplate3D.java:321)
at java.awt.GraphicsDevice.getBestConfiguration(GraphicsDevice.java:175)
at com.eteks.sweethome3d.j3d.Component3DManager.<init>(Component3DManager.java:65)
at com.eteks.sweethome3d.j3d.Component3DManager.getInstance(Component3DManager.java:103)
at com.eteks.sweethome3d.SweetHome3D.addComponent3DRenderingErrorObserver(SweetHome3D.java:506)
at com.eteks.sweethome3d.SweetHome3D.init(SweetHome3D.java:398)
at com.eteks.sweethome3d.SweetHome3D.main(SweetHome3D.java:298)
... 5 more
Please if you can help me with this.
[Mar 23, 2013, 3:00:00 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
I tried
I'm pretty sure this command can't run, because the -jar option must be followed by a Jar file and the -D option must be cited before the -jar option.
By the way, the README.TXT file states that you should set the directory in the the -Djava.ext.dirs option according to your system and its architecture, i.e. for Windows 7 32 bit, it should be -Djava.ext.dirs=lib/windows/i386;lib and not -Djava.ext.dirs=lib:lib/linux/i386.
[Mar 23, 2013, 8:21:11 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Gforce85
I have the same problem as the topic starter. I want to run this program from Eclipse ( under Windows 7 64 bit), and I have done what was in the "readme.text":
[IMG]http://i47.tinypic.com/2ivi8g2.jpg[/IMG]
But somehow I get the following error:
Error: Could not find or load main class Djava.ext.dirs=lib.windows.i386;lib,
What am I doing wrong?
[Mar 27, 2013, 1:40:31 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Gforce85
By the way how exactly do you edit posts?
[Mar 27, 2013, 1:43:48 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Gforce85, you forgot the hyphen in front of the D letter. -D is really a basic common option of the JVM.
[Mar 27, 2013, 2:46:43 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Gforce85
Thank you!! I changed it but now I get this error when i try to run the project:
Mar 27, 2013 2:21:36 PM javax.media.j3d.NativePipeline getSupportedOglVendor SEVERE: java.lang.UnsatisfiedLinkError: no j3dcore-ogl-chk in java.library.path Exception in thread "main" java.lang.UnsatisfiedLinkError: no j3dcore-d3d in java.library.path at java.lang.ClassLoader.loadLibrary(Unknown Source) at java.lang.Runtime.loadLibrary0(Unknown Source) at java.lang.System.loadLibrary(Unknown Source) at javax.media.j3d.NativePipeline$1.run(NativePipeline.java:231) at java.security.AccessController.doPrivileged(Native Method) at javax.media.j3d.NativePipeline.loadLibrary(NativePipeline.java:200) at javax.media.j3d.NativePipeline.loadLibraries(NativePipeline.java:157) at javax.media.j3d.MasterControl.loadLibraries(MasterControl.java:987) at javax.media.j3d.VirtualUniverse.<clinit>(VirtualUniverse.java:299) at javax.media.j3d.GraphicsConfigTemplate3D.getBestConfiguration(GraphicsConfigTemplate3D.java:321) at java.awt.GraphicsDevice.getBestConfiguration(Unknown Source) at com.eteks.sweethome3d.j3d.Component3DManager.<init>(Component3DManager.java:65) at com.eteks.sweethome3d.j3d.Component3DManager.getInstance(Component3DManager.java:103) at com.eteks.sweethome3d.SweetHome3D.addComponent3DRenderingErrorObserver(SweetHome3D.java:553) at com.eteks.sweethome3d.SweetHome3D.init(SweetHome3D.java:441) at com.eteks.sweethome3d.SweetHome3D.main(SweetHome3D.java:345) Exception in thread "AWT-EventQueue-0" java.lang.NoClassDefFoundError: Could not initialize class javax.media.j3d.VirtualUniverse at javax.media.j3d.GraphicsConfigTemplate3D.getBestConfiguration(GraphicsConfigTemplate3D.java:321) at java.awt.GraphicsDevice.getBestConfiguration(Unknown Source) at com.eteks.sweethome3d.j3d.Component3DManager.<init>(Component3DManager.java:65) at com.eteks.sweethome3d.j3d.Component3DManager.getInstance(Component3DManager.java:103) at com.eteks.sweethome3d.swing.HomeComponent3D.createComponent3D(HomeComponent3D.java:369) at com.eteks.sweethome3d.swing.HomeComponent3D.<init>(HomeComponent3D.java:289) at com.eteks.sweethome3d.swing.HomeComponent3D.<init>(HomeComponent3D.java:244) at com.eteks.sweethome3d.swing.SwingViewFactory.createView3D(SwingViewFactory.java:108) at com.eteks.sweethome3d.viewcontroller.HomeController3D.getView(HomeController3D.java:165) at com.eteks.sweethome3d.swing.HomePane.createActions(HomePane.java:327) at com.eteks.sweethome3d.swing.HomePane.<init>(HomePane.java:250) at com.eteks.sweethome3d.swing.SwingViewFactory.createHomeView(SwingViewFactory.java:122) at com.eteks.sweethome3d.viewcontroller.HomeController.getView(HomeController.java:330) at com.eteks.sweethome3d.HomeFramePane.<init>(HomeFramePane.java:92) at com.eteks.sweethome3d.HomeFrameController.getView(HomeFrameController.java:63) at com.eteks.sweethome3d.HomeFrameController.displayView(HomeFrameController.java:84) at com.eteks.sweethome3d.SweetHome3D$4.collectionChanged(SweetHome3D.java:401) at com.eteks.sweethome3d.model.CollectionChangeSupport.fireCollectionChanged(CollectionChangeSupport.ja
va:77) at com.eteks.sweethome3d.model.HomeApplication.addHome(HomeApplication.java:76) at com.eteks.sweethome3d.SweetHome3D.showDefaultHomeFrame(SweetHome3D.java:740) at com.eteks.sweethome3d.SweetHome3D.start(SweetHome3D.java:725) at com.eteks.sweethome3d.SweetHome3D$3$1.run(SweetHome3D.java:374) at java.awt.event.InvocationEvent.dispatch(Unknown Source) at java.awt.EventQueue.dispatchEventImpl(Unknown Source) at java.awt.EventQueue.access$200(Unknown Source) at java.awt.EventQueue$3.run(Unknown Source) at java.awt.EventQueue$3.run(Unknown Source) at java.security.AccessController.doPrivileged(Native Method) at java.security.ProtectionDomain$1.doIntersectionPrivilege(Unknown Source) at java.awt.EventQueue.dispatchEvent(Unknown Source) at java.awt.EventDispatchThread.pumpOneEventForFilters(Unknown Source) at java.awt.EventDispatchThread.pumpEventsForFilter(Unknown Source) at java.awt.EventDispatchThread.pumpEventsForHierarchy(Unknown Source) at java.awt.EventDispatchThread.pumpEvents(Unknown Source) at java.awt.EventDispatchThread.pumpEvents(Unknown Source) at java.awt.EventDispatchThread.run(Unknown Source)
I have also tried:
-Djava.ext.dirs=lib/windows/x64;lib
But this also doesn't work.
[Mar 27, 2013, 3:16:28 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Try with the VM option:
-Djava.library.path=lib/windows/i386
[Mar 27, 2013, 5:27:32 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Gforce85
Thank you! I have tried this, but I get the same error as I mentioned above.
[Mar 27, 2013, 6:26:41 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
