Re: V4 and Ubuntu 12.10
Hi hansmex,
Thanks you for the help.
The V4 seems to be working fine, can open my previous files.
Only one non critical issue. The menu bar is very dim. Almost the same color as the top dark panel of the software.
I have to blindly click in the area to get the drop down menu. Say, I want to go the Edit menu, I got to click blindly in about the area to get the drop down menu.
Anyway to adjust the font color of the menu? to make it brighter maybe.
Gan,
As far as I know, SH3D "borrows" colours and fonts from the theme of the operating system. So, if (for example) you have installed a pale blue theme with little contrast, than SH3D will be in pale blue with little contrast. If, on the other hand, you choose a black and white theme with high contrast, SH3D will show everything in black and white with high contrast. You may consider experimenting with a different theme.
