Total posts in this thread: 6
Previous Thread This topic has been viewed 4653 times and has 5 replies Next Thread
Llewelyn
United Kingdom
bad rendering
I noticed this in the 3D view. Part of the floor pattern from the level above shows through the ceiling in virtual visit mode. It doesn't seem to do this in a photo created from that view, so I guess not critical, but I don't see why it's happening even so, the levels look correct: level 0: height 8', level 1: height 8', floor 1', elevation 9'.
screen grab
basic rendered photo
[Mar 29, 2013, 10:52:31 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: bad rendering
Could you check whether you don't have twice a room defined at the upper level?
[Mar 29, 2013, 8:46:26 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
nigec
Re: bad rendering
I had something similar earlier tonight and it was the room defined twice, no idea how it happened
[Mar 29, 2013, 11:55:56 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Llewelyn
United Kingdom
Re: bad rendering
The room was not defined twice, I just checked. levels are 96" with 12" floor, set 108" apart. If I move the next level up to elevation 108.125" the problem goes away. I guess maybe if the ceiling had a texture, not a colour, it might not do that. seems the texture of the floor above is going all the way through the floor, not half-way as the wall textures do.
[Mar 30, 2013, 8:04:36 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: bad rendering
This could be also due to computing errors in the intersection between the room ceiling and the floor above. I saw a few cases where it didn't work as expected, for complex ceilings.
Could you send me the file that caused a problem if you still have it?
[Mar 30, 2013, 6:50:48 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Llewelyn
United Kingdom
Re: bad rendering
I do have it, I'll send it.
[Mar 31, 2013, 5:02:24 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
