problem with make a Photo
Hi, i have Problem with draw up a Photo. SHD start to make a picture and a in a few seconds are the button Save aktivate but the picture ist not redy, only a view quader with circle RGBY inside on the picture. Where ist the Problem. My Processor is i5 2500 K and the Grafickard ist the Intel 3000 HD (inside proc). Thanks for Help. P.S: Sweet Home is a great program! thanks. Peter
Re: problem with make a Photo
Please send me your file. It's been a long time since this kind of bug wasn't reported, but maybe you found a new special case. What version of Sweet Home 3D do you use?
centi's issue was solved by increasing the max memory used by the program. Hope this will help.
Thanks ! Tryin to but i dont understand how you can write something in a folder... " write the max memory Java option in that file, for example -Xmx1024m"
hi, yes that was the problem. THX for your help Puybaret! download as first SweetHome3D-4.0.jar not forget those! I just made a start.bat with this content: " @ echo off Java -Xmx4096m -jar "C:\Program Files (x86)\SweetHome3D\SweetHome3D-4.0.jar" exit " and again a problem lass in this world Peter
