United Kingdom
Want to create an arch model
hey guys, im currently a 3d design student and im building a venue within a arch. my mate just found this program (my jaw dropped at it :O) but i am just wondering if there is a way to create an arch shape with the existing features cant seem to work out a way with the walls currently, or if there is a model that i can install already out there? my exam is next week and i would love to be able to include this within my project.
Re: Want to create an arch model
Conner,
1 - On the 3D models page there's an arch (zip) you can use.
2 - If that isn't what you're looking for, then you can make your own arch. Basically, you make your design in the horizontal plane, then use Export as OBJ and Import as furniture. During importing you can rotate your model 90 degrees, to give it the correct orientation.
I tried now to do these changes, that you suggested, but whenever I load the model it doesn't create a hole in the wall anymore. Is there something I'm missing?
Yes, that works. Very nice. If it is a model you will use again, you may also want to consider using the FurnitureLibraryEditor to fix the settings (default size and door/window property).
