Total posts in this thread: 5
Previous Thread This topic has been viewed 6708 times and has 4 replies Next Thread
trojanrob
Poland
It is possible modify export to SVG format ?
Hello,
I want to add <rect class="btn" ... /> in SVG file after each <image ... />
This change is needed to image was clickable.
Any solutions , please.
Robert
[May 15, 2013, 10:20:10 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: It is possible modify export to SVG format ?
If you want to change SVG export, you should change the implementation of exportToSVG method in the PlanComponent class. In your case, maybe you could simply modify the end of paintFurniture method, to draw your rectangle when the paintMode is equal to PaintMode.EXPORT (you'll see there are already some similar tests for PAINT mode).
[May 15, 2013, 1:01:19 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
trojanrob
Poland
I think I described it wrong. sad
See my example
(transparent rectangle added manually) When click on image appears message box
<svg
<g ... >
<g ... >
<g ... >
<image x="0" y="0" width="256" height="256"... />
<rect class="btn" x="0" y="0" width="256" height="256" stroke="#fff" fill="#fff" fill-opacity="0" stroke-opacity="0" onclick="action" />
</g> <!-- transform -->
</g> <!-- default stroke -->
</svg> <!-- bounding box -->
This rectangle is transparent and clickable.
I don't want draw separate rectangle.
[May 15, 2013, 8:41:40 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Look at exportToSVG code, you'll see that SVGGraphics2D class coming from FreeHep library is used to generate SVG code. No idea what you can override there.
[May 15, 2013, 8:48:19 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
trojanrob
Poland
Problem solved. smile
Added "freehep-graphicsio-svg-2.2.1-sources" to SH3D source and modifiy class "SVGGraphics2D"
Thanks for the tip.
Robert
[May 16, 2013, 1:23:28 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
