Total posts in this thread: 5
Previous Thread This topic has been viewed 3832 times and has 4 replies Next Thread
Eo
Noisy reflection
I have a question about the reflection on the wall. There is a wall and an object. Wall - glossy colored ceramic tile, without figures. Tiles should be self-colored and smooth, but a reflection on the wall looks like a single points of light, or as noise. I want to get a smooth reflection. How do I make a reflection without noise? Sorry for my English.
Example:
http://www.mediafire.com/view/sp7rc8azzx7aed6/03_copy.png
Used texture:
http://www.mediafire.com/view/6i16iuwuz1jojbo/3.png
[Edit 1 times, last edit by Puybaret at May 30, 2013, 2:31:45 PM]
[May 30, 2013, 12:50:51 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: Noisy reflection
The easiest way to reduce noise is to create a twice (or more) larger image and reduced it once the image is computed with an image software.
[May 30, 2013, 2:33:10 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Eo
The twice larger image and then reduced looks much better. Thank you.
For comparison - original:
a twice larger image and reduced:
[Edit 1 times, last edit by Puybaret at May 30, 2013, 8:27:40 PM]
[May 30, 2013, 5:19:57 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
hal9000
Spain
Hmm... that may serve as a workaround, but when you're rendering an HD image which takes several hours to complete, the last thing you want is to multiply the rendering time by 4. worried
[May 30, 2013, 10:01:45 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
As said before, it was the easiest way.
The other way would be to increase antialiasing with the following parameter passed to the JVM (see also this message):
-Dcom.eteks.sweethome3d.j3d.PhotoRenderer.highQuality.antiAliasing.max=3
Rendering will go slower but not as much as computing a larger image.
[May 30, 2013, 10:28:36 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
