United Kingdom
3D View goes blank, how to "refresh"
The 3D view displayed in a separate window is blank when I switch back to SH3D after using other programs. Is there a simple way of "refreshing" the 3D view when I return to SH3D so the image returns?
Re: 3D View goes blank, how to "refresh"
Too bad, I thought this bug happens only under Java 7 with Java Web Start. Please try to resize Sweet Home 3D window or move the separators around the 3D view, it should refresh the 3D view.
United Kingdom
Thanks for the suggestion. I tried it already, but it doesn't work. I usually have to close the 3D view so it displays in the main window and then select Display in separate window again. This often takes about 2 minutes. Sometimes it is so unresponsive that I have the Exist the program and re-launch. Anyway it's not a big problem I just thought there may be a simple solution.
I had a very similiar problem: when opening any properties windows for furniture, the 3D view would go blank. I fixed this by killing this 3D view refresh code:
diff --git a/SweetHome3D/src/com/eteks/sweethome3d/j3d/Component3DManager.java b/SweetHome3D/src/com/eteks/sweethome3d/j3d/Component3DManager.java index 181000450..bcfb6ac3b 100644 --- a/SweetHome3D/src/com/eteks/sweethome3d/j3d/Component3DManager.java +++ b/SweetHome3D/src/com/eteks/sweethome3d/j3d/Component3DManager.java @@ -259,7 +259,7 @@ public class Component3DManager { canvas3D = new Canvas3D(configuration, offscreen); }
- if (!offscreen + if (false && !offscreen && OperatingSystem.isLinux() && OperatingSystem.isJavaVersionGreaterOrEqual("1.7")) { // Add a listener to the parent window once known that will repaint the canvas in 100 ms
