South Africa
Problem with Furniture Import
Having a problem with “Furniture Import Choose models”. On Choose model window shows Folders and Files, on my understanding double clicking in a folder should show files of that folder, my SH doesn’t on Files just shows Home files. Is this a bug or I’m wrong.
Re: Problem with Furniture Import
On my side, I don't see any issue in version 4.1. Please check again and give more details (with a screen capture if possible).
South Africa
Ubuntu 12.04 precise Sweet Home 3d 3.4
I tried to screen capture or taking picture but when in SH home can't do this at all. Receive from SH forum a window frame to add to furnisher but from SH can't open the Directory where this file is , I notice dragging the file into the drawing can't do this too come to the conclusion some thing is wrong with this version and decide to update to SH 4.1, Looking into Synaptic version 3.4 is the only one. Is version 4.1 works with my OS?. And how to update 3.4 to 4.1 Thank you
South Africa
Hi Hans,
Follow all you instructions, install SH 4.1,dragged the window ND511F into a plane worked then tried import furniture and it worked, because had to go out I left everything on that day. Next day power computer had an Ubuntu update and then restart computer carry on with SH3D Folders and Files cant show the files from different Folders only Home files and cant drag & drop just the same as before with ver. 3.4 I did uninstall and reinstalled with tarsrc file and unzip. Still not working properly.
