Total posts in this thread: 2
Previous Thread This topic has been viewed 3062 times and has 1 reply Next Thread
Babsi
smile Insulation
Hi!
Does someone know how to include insulation on the walls? I know that you can part the wall into two pieces (same width). But is there any way to get a wall for example with 25cm bricks and 20cm insulation?
Thanks
Babsi
[Jul 11, 2013, 4:47:49 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: Insulation
Babsi,
No, there's no simple way to do that.
However, you could draw double (or triple) walls, using exact coordinates, then use Modify walls -> Pattern in plan to distinguish between the walls.
Personally, I draw my cavity walls 30 cms thick, which is the standard in my country (10 cm outside wall, 10 cm cavity/insulation, 10 cm inside wall).
[Jul 12, 2013, 6:40:27 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
