Undo + Dragging
Hi, I downloaded the program. When I use it, I have things that don't work there, although they do work while using the program from the website. Two of the things are:
1. There is no possibility for Undo - It just doesn't exist. So i can't use Ctrl-Z at all
2. I can't drag furniture into the drawing. I can press Ctrl-Shitf-F, but then they appear always in a certain place in the drawing (From there it is possible to drag them of course).
Re: Undo + Dragging
SH3D does have an Undo and a Redo button, and it should be possible to drag a model into the 2D drawing window. If your version of SH3D doesn't provide these functions, delete it and re-install it. In case that doesn't solve the problem, please, provide more information on your system.
Spain
Re: Undo + Dragging
I have W7 and I have SH3D 4.1 in my "programs and features" list. How did you install it?
---------------------------------------- If a long walk every day were healthy, mailmen would be immortal.
Spain
Re: Undo + Dragging
Look at the SH3D shortcut properties to find the folder where it has been installed, then go an delete that folder. In addition, as prevously pointed by Hans, look at the FAQ to see what other folders may be using SH3D to store data or configuration files and delete them too.
Finally download the latest SH3D version INSTALLER for Windows and install it.
