Previous Thread This topic has been viewed 2589 times and has 2 replies Next Thread
pabloyepes
White sky
I am using version 4.1 on Linux. When I render an image of the whole building with an aerial view in level 4, the sky always comes out white. In the 3D properties I tried to use a texture of various skies, and using just a dark blue color. In all cases, on the rendering the sky looks white. I have also changed the brightness, but it does not change the result. Any ideas?
[Oct 3, 2013, 6:50:38 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: White sky
I guess it's white because you view a part of the generated sky in direction of the sun.
As stated in the help:
If you selected a color for the sky in the 3D view pane or if the current mode is Aerial view, a sky image computed according to the hour of the day is used for the rendering of the sky. If you chose a texture for the sky, that texture will always be used in Virtual visit mode whatever the selected hour.
So try to use a texture image for the sky.
[Oct 5, 2013, 7:35:09 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
pabloyepes
Re: White sky
I also tried with a texture, but it still shows a white sky. Any other ideas?
Thank you
[Oct 12, 2013, 11:11:23 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
