Previous Thread This topic has been viewed 3895 times and has 2 replies Next Thread
wal_dab
non-off screen not working
the program is not running at all although i use non-off screen
thank you
[Oct 29, 2013, 10:39:55 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: non-off screen not working
With no details about your system, I don't see how it's possible to help you. Did you try the other suggestions in the FAQ?
[Oct 30, 2013, 12:03:57 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
wal_dab
Sorry !!!
i use windows xp
Java 7 (build 1.7.0_45-b18
with an error text file start with:
A fatal error has been detected by the Java Runtime Environment:
# EXCEPTION_ACCESS_VIOLATION (0xc0000005) at pc=0x0561e29a, pid=4124, tid=232
# JRE version: Java(TM) SE Runtime Environment (7.0_45-b18) (build 1.7.0_45-b18)
# Java VM: Java HotSpot(TM) Client VM (24.45-b08 mixed mode, sharing windows-x86 )
# Problematic frame:
# C [ig4icd32.dll+0x70e29a]
# Failed to write core dump. Minidumps are not enabled by default on client versions of Windows
# If you would like to submit a bug report, please visit:
# http://bugreport.sun.com/bugreport/crash.jsp
# The crash happened outside the Java Virtual Machine in native code.
# See problematic frame for where to report the bug.
[Nov 13, 2013, 9:23:13 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
