Total posts in this thread: 12
Previous Thread This topic has been viewed 15482 times and has 11 replies Next Thread
sree.arun.kr
INDIA
rose Can I customize the render settings
Sir,I wish to customize the default render preset quality settings, the properties like anti-aliasing,texture filtering,caustic shadow.
Because this image takes 2 minute to render in 3rd quality render setting
http://s21.postimg.org/jnkz2tetj/002.jpg
But its shadow biasing is not good.
And this image taken 48 minute to render in 4th(Best) quality render
http://s13.postimg.org/se2d8qepz/003.jpg
If I can control over it then it is possible to adjust lights,texture resolution,objects snapping...
So Is it possible to inject a new code or edit any current code table?.
Thx in advance.
& Thanks SWEET Home 3D team for the new version
[Oct 31, 2013, 5:26:03 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: Can I customize the render settings
That sounds strange. Even my totally non-graphically minded machine works faster. A lot faster. Could there be another issue?
[Oct 31, 2013, 7:16:21 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Please read this thread and this one. It won't let you change all the parameters you wish but it's a nice start.
[Nov 1, 2013, 12:16:07 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
sree.arun.kr
INDIA
Thanks, Emmanuel Puybaret
Here is my trial Render-1 in HQ & it takes 6 minutes
with default settings,
-Xms1024m
-Xmx1536m
-Dcom.eteks.sweethome3d.j3d.PhotoRenderer.highQuality.globalIllumination=default
-Dcom.eteks.sweethome3d.j3d.PhotoRenderer.highQuality.diffusedBounces=1
-Dcom.eteks.sweethome3d.j3d.PhotoRenderer.highQuality.causticsPhotons=0
-Dcom.eteks.sweethome3d.j3d.PhotoRenderer.highQuality.shininessShader=silk
-Dcom.eteks.sweethome3d.j3d.PhotoRenderer.highQuality.antiAliasing.min=1
-Dcom.eteks.sweethome3d.j3d.PhotoRenderer.highQuality.antiAliasing.max=2
Here is my trial Render-2 in HQ & it takes 1 Hr.3minutes
with High settings,
-Xms1024m
-Xmx1536m
-Dcom.eteks.sweethome3d.j3d.PhotoRenderer.highQuality.globalIllumination=path
-Dcom.eteks.sweethome3d.j3d.PhotoRenderer.highQuality.diffusedBounces=3
-Dcom.eteks.sweethome3d.j3d.PhotoRenderer.highQuality.causticsPhotons=1000000
-Dcom.eteks.sweethome3d.j3d.PhotoRenderer.highQuality.shininessShader=default
& Here is my trial Render-3 in HQ & it takes 3minute.20Sec
with Optimize settings,
-Xms1024m
-Xmx1536m
-Dcom.eteks.sweethome3d.j3d.PhotoRenderer.highQuality.diffusedBounces=0
-Dcom.eteks.sweethome3d.j3d.PhotoRenderer.highQuality.antiAliasing.max=1
It give me a lots of work experience in all the way
Thank you once again for posting information's
. applause , love struck
[Nov 4, 2013, 6:41:24 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
sree.arun.kr
INDIA
I have a simple question that which keyboard shortcut used to visitor's head angle movement, in guide it shows a striken Up/down arrow which means shift+up/down arrow?. Not worked for me. 8(
[Nov 4, 2013, 7:00:00 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Emmanuel,
Would it be possible to create a Q5 for better rendering, or use Q4 for this?
I tried several times to make a "bat"-file to have better results, but I don't succeed in getting it to work.
If that's not possible, could someone make a small file that I can use, without me having to program anything?
[Nov 5, 2013, 8:34:21 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
sree.arun.kr
INDIA
rose Re: Can I customize the render settings
Hans download this file which has default settings
http://www.mediafire.com/?9vmlx54x3zv90nh
Then copy, paste to the location "C:\Program Files\Sweet Home 3D\SweetHome3D.exe" or the location where the "SweetHome3D.exe" located.
Here is the description for the commands
http://www.mediafire.com/?1hbx7495ki2iu7y
Edit the values or delete the lines if you want to customize.
Then save SweetHome3D.l4j.ini & start application "SweetHome3D.exe"
Improper or null value makes application crash then delete SweetHome3D.l4j.ini from the directory
To see Available Graphics memory Go to Win > Start > Run (or press Win-key+R),then type "DxDiag" & click display tab > Total memory=
Memory Values must be a multiple of 32.
Here is the file I uses to Exterior rendering
http://www.mediafire.com/?76y5jukvyqthgkl
Sorry for my bad .English.
peace dancing
[Nov 5, 2013, 5:16:31 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Sree,
Thanks for the information.
I use a PC with Ubuntu (Linux), not Windows. As far as I can see, there are no *.ini files on my computer, and I really don't know what to do with those files.
I start SH3D by double-clicking a file called SweetHome3D (881 bytes).
I have tried to modify that file, but without succes.
[Nov 5, 2013, 7:15:56 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Hans, it's really not complicated: simply add the -D... parameters one by one after
exec "$PROGRAM_DIR"/jre1.6.0_45/bin/java
in the SweetHome3D command file separating them with a space. Don't add line returns.
[Nov 6, 2013, 2:37:19 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Emmanuel,
I finally got it to work. I tried a few months ago, but I must have done something wrong.
The "Optimized settings" work OK under Q3 and Q4.
The "Default" settings work OK under Q3 and Q4.
When I insert the settings given as "High settings", it works OK under Q3, but under Q4 I get immediately a black picture. No calculation done. (Same file, same everything)
Best results always were obtained with Q3. Q4 consistently gives a lot of "speckling". (The infamous white artefacts)
My test renders were 1200x900 pixels, and the slowest finished in about 3 minutes on my quad core computer.
Seen (1) the rather large quality improvement and (2) the fact that increasingly people will use faster computers, maybe it is time to re-think the quality settings.
My suggestion would be something like this:
Q1 = current Q1 or Q2
Q2 = current Q3 or something similar
Q3 = "default" or "optimized" settings mentioned above (or something similar)
Q4 = Super high quality settings, lots of mirroring, ray tracing, bouncing, or whatever other settings you can think of, for a maximum result.
The tool tips for these settings could explain that Q1 is for older, slower computers, Q2 is for a better quality image, maybe duo core, Q3 is high quality, preferably quad core, etc.
This way you offer a greater flexibility without the need for lots of programming.
[Nov 6, 2013, 4:33:03 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
