Total posts in this thread: 5
Previous Thread This topic has been viewed 3470 times and has 4 replies Next Thread
A.Bahr
Change level of a surface
i cant find how to move a surface a little higher to link two stairs and build a 180 deg. stairs.
i think it's impossible and i just had to add a cubic object and size it as my need. is it right?
[Dec 30, 2013, 10:36:48 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: Change level of a surface
Learn how to Add a Level. I think that will solve uour problem.
[Dec 30, 2013, 9:17:01 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
A.Bahr
thanks again.
no . i can't define elevation for a surface and i think it's not possible in this version.
if it's possible please tell me how can i do it.
[Dec 30, 2013, 9:37:05 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Solution 1 - You can give all furniture objects any desired elevation.
So, insert a flat box as a halfway floor and give it the desired elevation.
Then, give the second staircase the same elevation as the halfway box.
Solution 2 - If you want to use a floor, do as follows:
- insert a new level;
- give that level an elevation that's half the height of your room;
- on the bottom level insert the first stairs;
- draw a room without a ceiling on the new level;
- staircase two goes on the halfway level and reaches the floor of the next floor.
Success.
[Dec 30, 2013, 11:29:26 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
A.Bahr
thanks you a lot. it's perfect.
[Dec 31, 2013, 2:30:46 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
