Total posts in this thread: 9
Previous Thread This topic has been viewed 5109 times and has 8 replies Next Thread
mmarts
3D view not updating, previously worked perfectly.
Hello i have the same problem as here http://www.sweethome3d.com/support/forum/viewthread_thread,4618
can someone help me?
thanks a lot
[Jan 2, 2014, 10:49:54 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: 3D view not updating, previously worked perfectly.
Did you try to run/open by clicking Launch Sweet Home 3D with Java Web Start from the download page? Provided you run a fairly recent version of Java, this should give you version 4.2a. If I understood the previous thread correctly, 4.2a has a fix to address you kind of issue. (And I assume there may be a full release at some point).
If you cannot run the Java Web Start version either, some info about your system (OS, Java version) would be useful if anyone is to comment.
[Jan 3, 2014, 8:19:08 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Did you try the Beta version proposed at the end of the page you mentioned?
[Jan 3, 2014, 9:57:16 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
mmarts
i use mac os 10.8.5 i install java 7.
the web start works.
hello mr puybaret i download it but sweet home couldn't start the 4.3 beta version.
[Jan 3, 2014, 5:23:18 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
mmarts
thanks for help but was not so helpful i have still the problem.
[Jan 6, 2014, 10:04:01 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
I'm very astonished this issue could happen under Mac OS X too. Could you send me your file please?
[Jan 6, 2014, 10:47:16 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
mmarts
thank you sir i send it to your e-mail
[Jan 9, 2014, 5:24:11 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
I had no problem to display the 3D view of your file on my computer.
Note that I fixed yesterday in the version 4.3 beta some more issues that could happen under Mac OS X in multiple screen environments. If this is your case, while waiting for the final release, please circumvent this issue this way if you can't use the beta version:
- Quit Sweet Home 3D
- Use your computer in one screen mode
- Open your file
- Display the 3D view (it should work)
- Save your file
- Turn on other screens again, and don't display the 3D view on other screens until the final release of version 4.3.
[Jan 9, 2014, 6:37:47 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
mmarts
thank you sir it works very well now Im impressed by your performance thanks a lot again (BEST)
[Jan 11, 2014, 11:38:17 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
