Re: open side shed rendering
Pretty hard to tell without more information. Is the roof the problem? (Flat roof = flat elevated box). Or the columns? (Use boxes shaped as columns). Draw a room for the arena to add texture. You probably need to use several levels.
Thanks very much for the replies. I was a tad terse I suppose.
Hansmex : Yes that is the idea except that the horse part has no sides - only columns at regular intervals to support the roof, and the residence part starts at verandah level.
okh: Thanks - re arena - yes I think the 'furniture object' trick would look after the gable roof and the columns and setting up 2 levels (ground - verandah, and verandah - residence roof; which is the same roof line as for the arena) for the residence.
Again - great to have this support. I have only been using the software for a day so I have a lot to learn!
Please study the example file I gave you. The veranda is just a room, and it's easy to gives rooms textures. Read the User's Guide or use the in-built Help.
Thanks again, your file has the verandah as a room - how did you get the room to show a 'roof' which would be the same as a 'floor' from the POV of layer 1?
I may have be way over-conceptualizing this way too much of course...
