Total posts in this thread: 5
Previous Thread This topic has been viewed 2437 times and has 4 replies Next Thread
KellyJesse
United States
Save Problem
Hey, I seem to be having troubles saving my project when I add certain pictures as the material for a picture frame. I'm using the online version.
I get the errors-
RecorderException: Can't save home
java.io.IOException: Server returned HTTP response code: 500
I'm not much of a tec guy so I have no clue what this means...
Thanks for the help!
[Jan 30, 2014, 6:51:58 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: Save Problem
It could be because one of your two projects reached the size limit authorized on the server, i.e. 3 MB. Sorry, but I won't increase that value. If you need to import more textures, you'll have to export your project and use the installer version.
[Jan 30, 2014, 8:26:54 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
KellyJesse
United States
Re: Save Problem
Awesome. thank you so much for the quick response!
[Jan 31, 2014, 1:47:01 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
HFfan
Re: Save Problem
Hi! I might be running into the same problem, that I cannot save my home due to it is too large in the online version. If I export the sh3d file and install the software, can I open it with the installed version?
I do not want to turn off my computer as I do not want to lose 6-7 hours of work :) I really like the progem!!! Thanks for it!
[Mar 9, 2014, 12:42:20 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: Save Problem
Yes. While keeping your browser open, you can test it: download Sweet Home 3D installer, run the installer, open with it the file exported from the online version, then close the webpage of the online version.
[Mar 9, 2014, 10:20:23 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
