Total posts in this thread: 5
Previous Thread This topic has been viewed 6418 times and has 4 replies Next Thread
hfrmobile
Lower Austria
Which is the best file format to import Model from SketchUp?
SketchUp offers exporting to following file formats:
Which one should I choose to use 3D-SketchUp models in SH3D?
[May 30, 2014, 12:26:37 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: Which is the best file format to import Model from SketchUp?
SH3D can read 3ds, dae, kmz and obj files.
You may want to experiment to find what is best for your needs.
[May 30, 2014, 7:30:01 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
sree.arun.kr
INDIA
I like .3ds because glass material & smooth object properties are work fine. And I like .obj because of its editable material file & most common 3D application support.
[May 30, 2014, 5:51:43 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
With the free version of Sketchup, your options are limited to Collada (.dae) - a tidy xml format (Sketchup .kmz export is just a compressed file with a .dae file + extra geo information in the .kml file). I have never had any problems with Sketchup's .dae export in SH3D, so I think I'd stick with the "default" Collada (.dae). Even if, in general, I prefer the clean, compact format of the .obj files... :-) ok
[May 30, 2014, 6:17:50 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
hfrmobile
Lower Austria
Thank you all for your answers!
Meanwhile I am using .dae (creating models using SketchUp Make = free version) which works fine. Also importing .dae files into SH3D works like a charm :)
[Jul 19, 2014, 10:35:48 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
