Previous Thread This topic has been viewed 11296 times and has 20 replies Next Thread
pmralbuquerque
Portugal
sad Sw 3D in Linux
I'm trying to install v4.4 in Linux Lite. After extracting the files, I find a file named 'SweetHome3d' with a command line symbol. If I read well the instructions on the site page, executing this file should install SW3D. But nothing happens.
What am I doing wrong, please?
I must say that I am an absolutely new user of Linux and know very very very little about this OS. sad The downloaded version is Linux 64 bits.
Thank you.
[Jun 15, 2014, 11:00:33 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: Sw 3D in Linux
You don't have to install SH3D.
1 - Unzip the file you downloaded.
2 - Right-click the SH-script (881 bytes)
3 - Choose Properties
4 - Under Permissions check the box before Allow execution as program
5 - Under Open with verify that the program uses Oracle Java 7 Runtime
6 - If necessary, uninstall all Java versions and install Oracle Java 7.
[Jun 15, 2014, 11:51:21 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: Sw 3D in Linux
You don't need to install Oracle Java with the installer version proposed on sweethome3d.com and SourceForge.net. Just double-click on the SweetHome3D file and it will run the program itself since there's no real installer program.
When you double-click on SweetHome3D, the system might prompt you to Run the program in a terminal or not. If it fails, run it in a terminal, and report here the issue that may appear in the terminal.
[Jun 15, 2014, 12:08:20 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
pmralbuquerque
Portugal
Re: Sw 3D in Linux
thank you for your answers Hansmex and Emmanuel, but I still haven't got it sad .
Let me try to explain better:
    first I download the file here ;
    second I extract the files, obtaining this folder;
    third I double click (or select run from the context menu) this file.
Then ... nothing happens confused .
Maybe there is something else I should do? Thank you again.
Regards.
[Jun 16, 2014, 5:44:46 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Yuri_fromBY
Belarus
Re: Sw 3D in Linux
I have the same problem, but with the x86 version in Ubuntu 14.04.
minsk@minsk-G41MT-D3V:~$ java -version
Picked up JAVA_TOOL_OPTIONS: -javaagent:/usr/share/java/jayatanaag.jar
java version "1.7.0_60"
Java(TM) SE Runtime Environment (build 1.7.0_60-b19)
Java HotSpot(TM) 64-Bit Server VM (build 24.60-b09, mixed mode)
minsk@minsk-G41MT-D3V:~$ javac -version
javac 1.7.0_60
[Jun 16, 2014, 6:17:01 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: Sw 3D in Linux
That sounds correct.
Try to run it in a Terminal window to see if some errors appear:
- Open a Terminal
- Drag and drop the SweetHome3D icon in the Terminal to get its path easily
- Type <Enter> to run it
- Report here what the Terminal says.
[Jun 16, 2014, 6:18:12 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Yuri_fromBY
Belarus
Re: Sw 3D in Linux
minsk@minsk-G41MT-D3V:~$ '/home/minsk/SweetHome3D-4.4/SweetHome3D'
Exception in thread "main" java.lang.UnsatisfiedLinkError: /home/minsk/SweetHome3D-4.4/jre1.6.0_45/lib/i386/xawt/libmawt.so: libXtst.so.6: cannot open shared object file: No such file or directory
at java.lang.ClassLoader$NativeLibrary.load(Native Method)
at java.lang.ClassLoader.loadLibrary0(Unknown Source)
at java.lang.ClassLoader.loadLibrary(Unknown Source)
at java.lang.Runtime.load0(Unknown Source)
at java.lang.System.load(Unknown Source)
at java.lang.Runtime.loadLibrary0(Unknown Source)
at java.lang.System.loadLibrary(Unknown Source)
at sun.security.action.LoadLibraryAction.run(Unknown Source)
at java.security.AccessController.doPrivileged(Native Method)
at sun.java2d.Disposer.<clinit>(Unknown Source)
at javax.imageio.stream.FileCacheImageInputStream.<init>(Unknown Source)
at com.sun.imageio.spi.InputStreamImageInputStreamSpi.createInputStreamInstance(Unknown Source)
at javax.imageio.ImageIO.createImageInputStream(Unknown Source)
at javax.imageio.ImageIO.read(Unknown Source)
at com.eteks.sweethome3d.swing.SwingTools.showSplashScreenWindow(Unknown Source)
at com.eteks.sweethome3d.SweetHome3D.init(Unknown Source)
at com.eteks.sweethome3d.SweetHome3D.main(Unknown Source)
[Jun 16, 2014, 6:41:17 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: Sw 3D in Linux
Maybe the answer to a similar problem will help you...
[Jun 17, 2014, 8:42:21 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Yuri_fromBY
Belarus
Re: Sw 3D in Linux
Emmanuel, thank you a lot!
"sudo apt-get install libxtst6:i386" - it helped.
[Jun 17, 2014, 9:36:04 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
amyelizabeth
confused Re: Sw 3D in Linux
Howdy,
Important info:
OS: Linux Trusty Tahr 14.04
Arch: 32bit
So I installed SW3D, or tried to. I extracted the files and when I click the app to run all the program does is open Gedit. I allowed the executing file as program, but it still won't work. I did move the file to a different location, Home file. Yet, the app still only opens in Gedit.
I have Java 6 and 7, I installed IcedTea. My OS has the latest version on libXtst.
I dragged and dropped the app into Terminal and it opens with the Terminal stating: Java 3D: implicit antialiasing enabled
However, I would like to run the app without having to route through Terminal. What am I doing wrong? crying
Any help is greatly appreciated!
Thank you
[Jun 19, 2014, 12:43:54 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
