Total posts in this thread: 6
Previous Thread This topic has been viewed 8366 times and has 5 replies Next Thread
JUGGERNAUT
swimming pool elevation
help please,
how do I recess my pool into the ground to give me the correct rendering in 3d view?
[Jul 17, 2014, 2:29:26 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: swimming pool elevation
Depends how you design your pool and whether you use a model of a pool. Try using a negative level (Add Level, and edit it to the "bottom of the pool", say -220cm).
You can draw your pool as a room with walls on the negative (subterranean) level where the walls protrude above ground to form the edge of the pool.
[Jul 20, 2014, 10:56:40 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
JUGGERNAUT
Thanks
your advice makes a lot of sense
I will try and then let you know the outcome
[Jul 21, 2014, 10:40:58 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Pools can be done with much of the same approach as terrain geometry. Posted an example of a pool (in sh3d format) with some extra pool models.
Hope this can be of help.
[Jul 22, 2014, 10:08:43 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Noticed the new blog post on how to design a swimming pool, with an example .sh3d file. Thanks, useful guidance to the basic steps of how to create a pool, using textures, curved walls and do model design with the help of SH3D. And a very nice design too.
How to design a swimming pool
[Sep 5, 2014, 9:37:37 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Jimgsm
Yes, you advice very useful, thanks)
[May 23, 2019, 3:35:24 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
