Belgium
Re: Problem show levels in 3D
I try but still the same problem. In 2d i see level by level but in 3d the problem keeps, I gave the floor a structuur but it din't help :(
BTW i make a mistake :) i sayed floor, but mean room (levels) i have 3 rooms (3 tabs) (3 levels) first room = basement = first level second room = first room = second level third room = second floor = third level
In 3D view in options, i can choose to show all levels of my house = no problem
But when i select show only selected room in 3D then the 3D show me the selected AND the underlying levels also
i mean when i selected the basement in the 2D: i see only the base in 3D.
When i select the first floor in 2D : i see the basement AND the first floor in 3D.
When i select the second floor in 2D: i see basement AND first level AND second level in 3D.
Is there a system to see ONLY the selected room in 2D so when i select the second room i see ONLY the second room in 3D.
The solution that i have for the moment is to save al the floors in different file's.
Groofertje, don't search further. The real name of the Display selected level menu item should be Display selected level and below levels.
Menu items can’t be too long and the tool tip of this item already shows this longer information. Note also that since 2014, the ability to hide one or more levels have been added to the program.
[Edit 1 times,
last edit by Puybaret at Nov 20, 2022, 1:59:09 PM]
