Total posts in this thread: 2
Previous Thread This topic has been viewed 4750 times and has 1 reply Next Thread
prettyrustic
creating curved lines
I have a round kitchen and all the cabinets run along the outside wall. How do I create curved countertops for my kitchen cabinets?
[Oct 24, 2014, 10:17:13 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: creating curved lines
If you cannot find a suitable model (or geometric shape that matches) online, you could:
- Open a new sh3d file.
- Draw (thin) walls with arc extents set correctly to outline your countertop.
- Close off walls, to create a "room" with shape identical to your countertop.
- Use room-tool, double-click to create a room within the walls.
- Select the room, export selection to .obj format.
- Import the .obj file as furniture (adjust "countertop" thickness and elevation).
It requires some accurate measuring and tweaking to get perfect, but once you get the hang of it, it is not too hard. smile Good luck. ok
[Oct 25, 2014, 5:42:07 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
