Previous Thread This topic has been viewed 7378 times and has 13 replies Next Thread
JadeL
South Africa
angry Creating video no video
Good day
I made sure when i create my video that all movement points are created but after the video is created i save the file (default file format is .MOV ) its creates a 0KB .mov file and there is no video after 10min of creating a video.
Please help.
Thanks in advance
Jade
[Nov 13, 2014, 6:03:13 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: Creating video no video
So to follow your previous post, you seem to be able to save the MOV file now, even if it's empty, right? What did you change?
[Nov 13, 2014, 11:00:30 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
JadeL
South Africa
Hi there Emmanuel with previous tread -- could not get it to work so all i did in this post is installed program on another hardrive instead of C drive i installed in D drive with no windows on D drive. Yes i can save MOV file now but its empty why does this happen..
[Nov 13, 2014, 11:25:14 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
If I knew the answer, I would have given it already!
Did you try to create a SweetHome3D.l4j.ini as suggested in my previous answer?
[Nov 13, 2014, 11:55:41 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
JadeL
South Africa
yes i did and copied it in the c:/programs files/sweet home 3d/ and still doesn't work. Actual fact it doesn't even open the program
[Nov 13, 2014, 12:47:06 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Hum, Jade, I'm ok to help you, but if you don't report the problems you encountered with the suggestions I made, then open an other (angry) thread to complain again, it's not going to be easy... sad
Are you sure that you didn't forget the hyphen in front of Dcom.eteks.sweethome3d.tools.temporarySubFolder....?
Without it, it can't work...
[Nov 13, 2014, 4:28:18 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
JadeL
South Africa
Hi Emanuel.
This is how i did it is it correct :
-Dcom.eteks.sweethome3d.tools.temporarySubFolder=C:\temp\
Please advise if correct
Thanks
[Nov 14, 2014, 7:00:49 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
JadeL
South Africa
the file name is SweetHome3D.l4j.ini rename txt file to .ini
[Nov 14, 2014, 7:01:29 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
JadeL
South Africa
copied in program files / sweet home 3d
[Nov 14, 2014, 7:02:10 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
This sounds correct if C:\temp folder exists
[Nov 14, 2014, 12:42:09 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
