Total posts in this thread: 2
Previous Thread This topic has been viewed 2879 times and has 1 reply Next Thread
cspal
How to join four wals at forth corner?
I'm using SweetHome 3D version 4,5.
I have created a house with four walls and setup inner and outer colors of these walls, but on the last corner this is look as on the image bellow.
On that corner the two walls are not connected because at that corner there is the start point of the first wall and the end point of the last wall.
How can be these two walls join together?
On the images bellow one can see the joined corner:
and the problematic corner that is not joined yet:
So how can one join these walls at this corer?
Regards, from Pal
[Dec 22, 2014, 8:56:56 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: How to join four wals at forth corner?
1 - When drawing the last wall, move the cursor on the starting point. It will change to a crosshair. Now double-click and the last wall will connect to the first wall.
2 - Other method: install the AdvancedEdit plug-in and use the function ConnectWalls.
[Dec 22, 2014, 10:28:34 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
