Previous Thread This topic has been viewed 4955 times and has 2 replies Next Thread
santbose
India
confused Inclined wall at 45 degree with the ground
Hi All..... first thing first. I am using this wonderful software for last couple of months. I must say I am enjoying it very much. I am designing a sports centre with swimming pool in it. In the plan I need to front wall of the main lounge to be inclined as below in an angle of say 45 degree with the ground level:
/wall
__/_________ground (lawn)__________________
Can any one help me with this please. Once I finish the project drawings will definitely share it in the forum.
Santanu Bose
India
[Edit 1 times, last edit by Puybaret at Jan 21, 2015, 10:05:48 AM]
[Jan 21, 2015, 6:09:03 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: Inclined wall at 45 degree with the ground
Alas, standard walls cannot be angled, but using the roof principle, the fix is relatively easy: Draw the wall, insert windows, select wall+windows, export selection as .obj, import and rotate. Then you need to angle (slope) the ends of the joining walls (if the angle leans inwards) or fill gap with triangles (if it leans outwards).
[Jan 21, 2015, 4:20:54 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
santbose
India
Thanks Okh. Will try and get back.
[Jan 22, 2015, 5:25:11 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
