Total posts in this thread: 2
Previous Thread This topic has been viewed 3564 times and has 1 reply Next Thread
RogerTE
Setting and locking building external (or internal) size
This is probably a stupid question, but is it possible to enter the overall dimensions of a rectangular building when creating the external walls and then locking them so they don't change?
I have tried using "create room" and "create walls", but it is possible to be slightly non-square, especially on large buildings.
Thanks
Roger
[Feb 5, 2015, 12:13:14 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: Setting and locking building external (or internal) size
Assuming I understand what you mean:
- When drawing a wall, or room, you can press Enter to insert values manually.
- While you draw, you can use ALT to disable magnetism (Mac:CMD , Linux: Shift+Alt ) if the angles are off.
- After a wall is completed, you can modify the properties to set exact values.
- After a room is completed, you can move each corner (and if you have the AdvancedEdit plugin, you can enter exact corner values.
- If you have closed walls, you can double-click with the room tool to insert the room automatically.
- If you have a room, you can double-click with the wall tool to create the walls around that room automatically.
- And after you have drawn your walls / rooms, you can click the little padlock top left 2D pane to lock (all items that are part of base plan).
[Feb 5, 2015, 3:26:46 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
