Total posts in this thread: 5
Previous Thread This topic has been viewed 4482 times and has 4 replies Next Thread
bennett
How to install a L shaped staircase
smile I am working on a project which has two floors and is basically complete except for the staircase between the levels. The first floor perimeter walls are a template for the second floor perimeter walls. The guard wall around what would be the second floor L shaped opening is in perfect position. I have altered the stairs height to force the staircase through the second floor elevation. thinking that would punch a hole in the second floor, but no luck. I am trying to install a L Shaped Stairs 3ds model. The original model format was SKP, which I chose to export as 3ds using SketchUp. I could have or still can export as KMZ or dae. The model fits perfectly and at one time the top step was flush with the second floor, floor elevation, until I raised it about one step trying to punch a hole through the floor. I can easily reset if required. I hope I have provided enough information that a good friend on line could direct me to a successful conclusion. Thanking you in advance. Best regards, Ben :)
[Feb 25, 2015, 2:35:13 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: How to install a L shaped staircase
When you imported your 3ds model, did you check the box for "staircase" in the import dialogue? ok
[Feb 25, 2015, 2:55:35 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
bennett
Thxs for getting back. The answer is yes movable was checked which I changed to staircase
[Feb 25, 2015, 10:37:01 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
It is the Staircase option that should make the model cut an opening in the ceiling and floor above. (Movable is not relevant for the cut-out, but should be checked by default and be greyed out if you check Staircase or Door/window).
So if Staircase is checked for the model you should get a rectangular opening above the entire staircase. But that is not always what you want in the case of an L-shaped staricase.
Now, if you want a custom cut-out, e.g. one that follows the L shape of the stairs, you have three options:
- Draw floor/room manually to fit staircase (staircase option should not be checked when importing model).
- Find a model with cut-out already defined for SH3D.
- Add the cut-out shape yourself.
The latter option will require you to use the Furniture Library Editor (available on the Download page) and enter the cut-out shape yourself. On page 6 of the SVG guide, there is an example of what the SVG cut-out could look like for an L shaped staircase (probably something like M0,0 v1 h1 v-0.5 h-0.5 v-0.5 z depending on the rotation of the model - this example assumes orientation similar to an L cut anti-clockwise).
You can see the result of L shaped cut-outs in SF 3D Models 329 example file. And BTW, please feel free to use any staircase in the file if that can be of help.
PS - it is not possible to define the cut-out definition directly in SH3D or in Sketchup. As for model export from Sketchup, using the .DAE format is a good idea (.KMZ is basically the same, only zipped). I find it is the format with least surprises and it is also available in the free version of Sketchup.
[Feb 26, 2015, 9:02:58 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
bennett
OKH Thanks for being so gracious with your knowledge and time. I have been sidetracked, but am ready to try again. I will keep you posted. Thxs again. Ben
p.s. wish me luck :) :)
[Mar 6, 2015, 11:00:16 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
