Total posts in this thread: 5
Previous Thread This topic has been viewed 5223 times and has 4 replies Next Thread
gruby33
Bad picture quality on lv3
Hello.
I make room in SH3D. A take a picture and chose lv3. On lv3 always is bad image quality (noise). On lv1 and lv2 and lv4 (creates 20min...) it`s all OK.
Ultrabook HP, i5-4200U, HD4400, 4GB RAM, Win 8.1 Pro 64bit.
P.S Image from lv3:
https://www.mediafire.com/convkey/e1a4/q5oy3ms263eha8w6g.jpg
[Mar 23, 2015, 11:33:03 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: Bad picture quality on lv3
A better quality would make it much slower to compute.
If ever, you want to improve quality settings of level 3, you can compute a larger a image and reduce its size with an image tool. You can also set the properties com.eteks.sweethome3d.j3d.PhotoRenderer.lowQuality.antiAliasing.min to 1 and com.eteks.sweethome3d.j3d.PhotoRenderer.lowQuality.antiAliasing.max to 2, as suggested here.
[Mar 25, 2015, 8:36:31 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
gruby33
Thanks.
This is it :)
[Mar 26, 2015, 10:07:35 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
carlob
hy puybaret
sorry but i don't understand where i can change the properties for high resolution, i see your posted link but i don't know what have i do, i have to create a file ini? and if yes, where i have to put it?
thank a lot
[May 20, 2015, 1:29:43 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Did you try to change the width and height in pixels to a much higher value? This is the easiest way to remove noise, even if not the most efficient (in terms of required computer power).
[May 20, 2015, 8:46:41 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
