Total posts in this thread: 6
Previous Thread This topic has been viewed 3493 times and has 5 replies Next Thread
shanghai_nin
How to fill in blank space between walls and 6 corner bathtub
Hello,
whats is the best way in terms of having only one surface to fill in the blank space between 2 walls and a 6 corner bathtub?
Greetings
[Mar 31, 2015, 4:07:30 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: How to fill in blank space between walls and 6 corner bathtub
Welcome smile
Would you have any image of the "6 corner bathtub" you want to test?
Just post its URL.
[Apr 1, 2015, 12:02:29 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
shanghai_nin
Hello Emmanuel,
thank you for your message and time.
Please have a look
http://www.kaldewei.de/produkte/whirlen/ambie...oduct/novola-duo-6-1.html
I made some pictures in SH3D, how do I attach these in here?
Greetings
[Apr 1, 2015, 4:30:33 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
You could add some correctly oriented triangles in the corners.
[Apr 1, 2015, 5:10:26 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
shanghai_nin
Hello,
the issue is that only one triangle is not enough, there is both a space between the two walls and the tub. 2 boxes and 1 triangle might do the trick, however this is not one surface how I would like it to be. Is there an add command (not only group) to add 3 separate items into one (a boolean +) ?
Greetings
[Apr 1, 2015, 5:16:20 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
You could add a level, change its elevation to make it match the height of the bathtub, then draw a room that would fill the space like you want.
Then, if you don't want to really keep that fake level, export to OBJ format the room you drew, delete that level, reimport the OBJ file as a piece of furniture and place it where you want.
Hope you can do it...
[Apr 1, 2015, 6:35:20 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
