Total posts in this thread: 5
Previous Thread This topic has been viewed 3316 times and has 4 replies Next Thread
Bojoglobe
New Zealand
Turning on lighting.
HI all,
Great program, thanks to the developers. If you could help, I'm a newbe and can't make the lights "work", I can't find a way to make it appear they are working or showing any glow.
I have done a lot of searching but can't find a direct answer.
I'd appreciate some direction please.
Thanks
Bob
[May 24, 2015, 9:02:55 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: Turning on lighting.
Until now, lights never glow in the 3D view and you can see their effect only in the photo creation tool when you choose one of the 2 best qualities.
[May 25, 2015, 9:41:24 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Bojoglobe
New Zealand
Thanks Emanuel,
Much appreciated, I'll check that.
Bob
[May 25, 2015, 10:51:30 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
mazoola
Bob -
As someone currently stuck using an underpowered, backup PC, I usually run a quick 'lighting check' run at low resolution (200 to 300 pixels wide) and level 3 quality; that's usually enough to sanity-check most lighting options. (IIRC, only a few, higher-level ray-tracing features [reflection, refraction] show up only at level 4.) Once I've adjusted lighting to eliminate burnout and shaded areas, I render at full size and level 4.
Maz
[May 25, 2015, 11:09:44 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
mazaya
I'll check that.
[May 30, 2015, 9:17:19 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
