Total posts in this thread: 20
Posts: 20   Pages: 2   [ 1 2 | Next Page ]
Previous Thread This topic has been viewed 11806 times and has 19 replies Next Thread
WhiteVanMan
Crash on clicking preferences
Hi
I am using sweethome 3d on an Arch Linux system. Every time I click on preferences the program shuts down instantly and I have to restart it.
Thanks
[Jul 16, 2015, 11:17:07 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: Crash on clicking preferences
Read the FAQ for solutions.
[Jul 16, 2015, 5:00:20 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
WhiteVanMan
Hi
Thanks for the reply. I found the relevant part in the FAQ after posting. It works if I download the webstart file but I would rather use the sweethome3d from the arch linux repositories, its tidier and looks after the updating. I cannot find the .sf file to amend with -Dcom.eteks.sweethome3d.j3d.checkOffScreenSupport=false arch must have a different method of organising its files. Do you know where it is, is it in a .jar file?
[Jul 16, 2015, 7:44:40 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
I don't know. I use Ubuntu in combination with the installed version, which I download from the website. Installation is no more than extracting the zipped file into a directory.
If you use the web star version, make sure you have Java 6 installed on your system. Other java versions cause problems.
[Jul 16, 2015, 8:06:38 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
WhiteVanMan
Many thanks
[Jul 16, 2015, 9:30:03 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
infozhab
Erm, same here on Fedora 22, including the inability to fix as per FAQ recommends. Appending offscreen-false won't do the trick.
Actually, I only need metric measures enabled - is it possible to do it manually?
[Aug 1, 2015, 1:40:27 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
goetz
I also need to only change the measurements system to metric (the international). How to do it? Editing some config file?
java -jar /usr/share/java/sweethome3d.jar -Dcom.eteks.sweethome3d.j3d.checkOffScreenSupport=false
Doesn't work.
Arch Linux, jre8-openjdk 8.u66, sweethome3d 5.1
[Nov 19, 2015, 12:52:46 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
goetz
The web method worked.
I installed icedtea-web 1.6.1, which provides javaws, then using the jnlp file http://www.sweethome3d.com/SweetHome3D-NoOffscreen.jnlp from the FAQ:
javaws SweetHome3D-NoOffscreen.jnlp
Or to just to change the measurement unit, edit ~/.eteks/sweethome3d/preferences.xml to a sane value:
<entry key="extensibleUnit">METER</entry>
or
<entry key="extensibleUnit">CENTIMETER</entry>
[Nov 19, 2015, 1:25:19 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Doesn't work.
Are you sure that the .jar file you tried in the command is the Jar executable file available at the end of Download page?
[Nov 19, 2015, 6:34:01 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
goetz
In Arch Linux, the script used to build the installable package, downloads the "Sweet Home 3D executable jar (25.7 MB, same size)" and renames it from SweetHome3D-5.1.jar to sweethome3d.jar in the /usr/share/java/ path. So it should be the same file.
[Nov 19, 2015, 7:23:33 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
