Previous Thread This topic has been viewed 11865 times and has 12 replies Next Thread
hornetster
Australia
How to delete items (specifically walls...)
Just started using this, but for the life of me, can't figure out how to delete anything. eg create a wall, decide it's wrong, and want to delete, so select it, right click, and click delete, all it seems to do is unselect it... if I modify and make it 0 length, I can *sort* of (sometimes) delete it, but this seems rather wrong...
Please help.
[Nov 18, 2015, 12:15:10 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
HawkDawg
Re: How to delete items (specifically walls...)
It should work as you have tried.
What operating system are you using?
Could it be an issue with your mouse?
Another thing you could try is highlighting the wall or other item and hit the delete key on your keyboard.
Hawk
[Edit 1 times, last edit by HawkDawg at Nov 18, 2015, 7:37:05 AM]
[Nov 18, 2015, 3:41:54 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Does it happen even on a new file?
[Nov 18, 2015, 9:36:14 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
hornetster
Australia
Yep, have just installed, and only trying to create a new file. All I have done is create a wall, then try to delete it.. Have tried the various options to delete - right-click menu, delete key, top menus - all give the same response (ie just appears to "unselect" the wall - not delete)
Running Opensuse Leap 42.1 x64.
Did have the issue with Preferences closing the app, but then ran the SweetHome3D-NoOffscreen link.
All keys and mouse work fine with every other app...
Not sure.
[Nov 18, 2015, 10:00:31 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
hornetster
Australia
Anyone? Should I perhaps see if I can update Java, although apparently I am up to date?
[Nov 20, 2015, 12:05:12 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Did you try with the installer version available on Download page or with an other distribution? What does the About dialog says?
[Nov 20, 2015, 8:30:30 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
hornetster
Australia
Thanks for that Puybaret.
Did the trick! Just trying to think where I installed the original from - think it MAY have bee from the opensuse software build page...
All good, now working.
Thanks to all.
[Nov 21, 2015, 9:37:49 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
vinmathi
I have the same problem as reported by 'hornetster'. Not able to delete the wall. I have just installed it through Sweet Home 3D with Java Web Start. My OS is Ubuntu 14.04 LTS. Version of the Java is given below
java -version
java version "1.7.0_95"
OpenJDK Runtime Environment (IcedTea 2.6.4) (7u95-2.6.4-0ubuntu0.14.04.1)
OpenJDK 64-Bit Server VM (build 24.95-b01, mixed mode)
[Feb 20, 2016, 5:17:47 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
As said previously, use the installer version.
[Feb 20, 2016, 5:28:04 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
vinmathi
Installer version is working fine.
Thanks for your help.
[Feb 21, 2016, 4:10:31 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
