Visibilité du toit / hidden roof
-- FR -- Bonjour, J'ai un problème avec le rendu d'une toiture. En effet, il n'apparaît que sous certains angles. Impossible d'avoir le toit en entier... Quel est le problème ?
Merci
-- EN -- I have a problem with rendering the roof. Indeed , there appears to under CERTAIN angles. Could not have the entire roof ... What's The Problem ?
Re: Visibilité du toit / hidden roof
It looks like the triangles that you use are single sided and the visible side is oriented towards the ground. When you import them, you should select the option Invert back and front faces at the second step of Furniture import wizard. You could also use some double sided triangles or simply use this simple triangle that you'll resize.
