Total posts in this thread: 4
Previous Thread This topic has been viewed 2307 times and has 3 replies Next Thread
Tiso
Using light, how can I set ?
Hi there,
I have tried to set a light into a room, but I dont the same atmosphere as show in some picture of the website.
Is there a trick to do it?
Thanks
[Feb 15, 2016, 9:37:42 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: Using light, how can I set ?
It's difficult to give an advice without seeing any picture(s).
In general, if you want more or less realistic lighting of a room, you should:
- disable Add ceiling lights in the Create photo dialogue
- use large lights (e.g. 100x100x100 cm) at a low strength to give a basic light level in the room
- use smaller accent lights to indicate other light sources
- experiment, experiment, experiment.
[Feb 15, 2016, 11:02:15 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Tiso
Thank you for your quick replay, but I don't see any "add ceiling light" in the create photo dialog box.
[Feb 15, 2016, 2:52:15 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
SnakeGB
move the quality slider to best then it will show add ceiling loght check box
[Feb 15, 2016, 8:50:10 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
