Previous Thread This topic has been viewed 6130 times and has 2 replies Next Thread
CCPT
Join (or merge) 2 adjacent walls?
Hi
When I draw 2 or more walls in a single process, adjacent walls are drawn with a "join" between them:
However if I draw the adjacent walls at different times they don't "join" together - and has a result if the 2 walls have different colors in 3d view we see a vertical stripe on the union off the 2 walls:
Is it possible to "merge" these 2 walls?
Thanks,
CC
[Mar 5, 2016, 12:14:28 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: Join (or merge) 2 adjacent walls?
The #4 Advanced plan editing plug-in available from the SH3D SF plug-ins allows you to connect / join two selected walls (that run in the 'same' direction, when they are selected in the correct order). ok
[Mar 5, 2016, 3:18:00 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
CCPT
applause Re: Join (or merge) 2 adjacent walls?
Thank you - this plugin solved my issue.
[Mar 5, 2016, 10:22:19 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
