Total posts in this thread: 2
Previous Thread This topic has been viewed 4031 times and has 1 reply Next Thread
bbxrider
United States
2d images in my 3d drawing
Can I create a 2D drawing with sweet home 3D? jar version
Just looking from top down, so the symbols look basically like this:
what I get now is the space area carved out instead of a representative 2D outline of the toilet, vanity, etc, there's a picture of it inside the area taken up by the object
it can render it in 3D as well thats great but for now just need the top down outline picture
Do I need to import some type of 2D library? that just doesn't come with the default sweethome jar version.
Can't get the installed program version working due to the driver issue and for all the posts I'm not finding a clear solution to what new drivers I may need
[Mar 28, 2016, 7:48:12 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: 2d images in my 3d drawing
Maybe you have already found out, but there are two standard ways of representing furniture items in SH3D: try to toggle Preferences - Furniture icons in plan. The Top view may not be perfect for correct architectural symbols, but a decent approximation which allows any imported object to be represented in the 2D view.
For models with additional SH3D properties, i.e. defined in a library file (.sh3f) - it is possible to have customised "planIcons". However, you may not be able to find find an existing library with exactly the symbols you want.
If you still really wish to create an exact representation the way you describe it, you could make your own by:
1) Creating a library (with the Furniture Library Editor).
2) Editing the contents of the .sh3f file (which is a .zip file).
- add a planIcon# property in the PluginFurnitureCatalog.properties to a model in the library,
- add a file with the plan icon you want.
There is more info on advanced editing in the forum/documentation if you wish to try. Where to start really depends whether the above sounds very easy, or very complicated to you... smile
[Mar 30, 2016, 7:57:32 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
