Canada
Elevation Problem
I have a drawing with 3 different levels. basically my basement, then you come up the stairs, and there is a little landing to go into the backyard, then there is another set of stairs 18" high(3 steps) then the main floor.
Re: Elevation Problem
When you get this kind of mixed colors on walls, it generally means that there are some superimposed walls at that place. You should probably try to adjust the height of your walls.
