Total posts in this thread: 5
Previous Thread This topic has been viewed 3741 times and has 4 replies Next Thread
Stopgap
Australia
Rogue item in aerial view
My aerial view appears to contain a "rogue" item that does not appear on my plan. The item is some distance from the main plan and consequently causes the aerial view to be "zoomed out".
The item appears on the left of the aerial view, so zooming out on the plan doesn't reveal it, as this only shows white space below and to the right.
I've also tried cutting and pasting everything, but that hasn't helped.
Has anyone had a similar experience and found a way to resolve it?
Thanks for any help.
[Jun 13, 2016, 12:36:15 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: Rogue item in aerial view
Choose Edit > Select all menu item and zoom out in the plan. This should help you to find where this item is placed in the plan and delete it.
[Jun 13, 2016, 12:33:13 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Stopgap
Australia
No, that doesn't help. The item doesn't seem to get picked up in the plan - only the aerial view.
I can send a screen dump if that helps? Not sure how to upload them here.
[Jun 14, 2016, 12:03:28 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
HawkDawg
Maybe this topic will help.
http://www.sweethome3d.com/support/forum/viewthread_thread,1886
Hawk
[Jun 15, 2016, 2:19:31 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Stopgap
Australia
I have resolved it - thanks for you help.
I gradually copied and pasted sections of the plan into a new plan until the issue re-appeared, and then back tracked until it didn't.
It turned out to be an item (a microwave actually) on the plan, but it showed up separate in the aerial view, which caused it to be zoomed out.
Thanks again.
[Jun 15, 2016, 10:18:34 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
