Re: heating, Water and air pipes
Hi Yes there is a way to do pipes.
I did it by making a small circular wall and then exporting it as a piece of furniture. Then re-importing this and scaling it. I also made a small rectangular set of walls and exported that as trunking.
Sorry forgot to say also made right angle bends in both tube and trunking by using sloping walls to make half of a bend then imported it twice to get 2 halves. Then set them up as right angle bend and exported the 2 together to make bend.
Romania
I use some furniture library for pipes or wire. This is the result:
