The plug-in supports English and French but it is possible to add other languages based on the ApplicationPlugin_en.properties template.
Based on these instructions , the addition of a language can be done as follows: 1-unzip the PhotoVideoRendering-VERSION.zip file 2-transform the .sh3p into .zip 3-paste your file ApplicationPlugin_LANGUAGE.properties 4-transform the .zip into .sh3p
For any additional language integration directly to the plug-in for future versions, you can contact me .
---------------------------------------- ApplicationPlugin_en.properties
(4768 bytes)
(Download count: 520)
(Translation template)
EnkoNyito
[Edit 1 times,
last edit by enkonyito at Sep 14, 2017, 3:49:04 AM]
Note to translators.
You can translate the label of parameters (rendering properties) by putting your translation in parentheses and separated from the English keyword by a space. Example: RenderingPropertiesView.aAminLabel=antiAliasing.min (\u6700 \u5C0F \u9297 \u92F8 \u9F52):
This structure must be respected otherwise the modifications of the parameters will not be taken into account for your translated file.
EnkoNyito
Thank very much for the help of Enko Nyito, so that the renderer has more choice, I also translated the traditional Chinese and Simplified Chinese, download: http://sync.hamicloud.net/_oops/scleea/seh
Brasil
http://i66.tinypic.com/jruq0l.jpg[/IMG[/img] Sorry, for my English. I have a problem. I have version 5.6 of the software and I can not create a photo. I click on create photo and it loads but an error appears on the screen, a small icon with an 'x' in the middle. Before I could create photos normally, but now I have this problem. I even formatted my computer to see if it was memory, but it is not. Please help m e.
[moderated]
[Edit 1 times,
last edit by Puybaret at Nov 19, 2017, 8:34:41 AM]
Geovani141, this error might happen when the program doesn't have enough RAM to work. Read the FAQ to increase the maximum RAM that Sweet Home 3D can use.
Some details about the video rendering.
- curved line for camera path The curved line path is created automatically when there is a difference in orientation between 2 recorded positions.
- variable speed according to distance The greater the distance between 2 recorded positions, the faster the movement speed. Conversely, the shorter the distance, the slower the speed.
Practical tip to see the difference between a straight line path and a curved line path. You can save your path in the standard video panel and then open the video plugin. Since the positions recorded are the same, some parts of the path may be curved and the speed different depending on the distance.
At the next version!
EnkoNyito
selection, in the simple photo rendering panel, of available LookAndFeels
other minor bugs fixes and enhancements
(translation template)
EnkoNyito
[Edit 1 times,
last edit by enkonyito at Jan 30, 2018, 1:05:54 AM]
To add additional options, I decreased the size of the image preview and since version 1.4 the size of the panel changes depending on the look and feel chosen.
But to answer your question, yes it is possible to increase the size of the image preview.
EnkoNyito
