Previous Thread This topic has been viewed 6087 times and has 13 replies Next Thread
jkhoo
Malaysia
Connecting 2 different levels of ceiling with right angle board.
My ceiling have 2 levels, one at 2900mm and another at 3100mm. How can i connect both of them together with a right angle ceiling?
[Dec 25, 2016, 8:59:50 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: Connecting 2 different levels of ceiling with right angle board.
If I understood, with a raised box with correct dimensions. smile
[Dec 25, 2016, 7:47:33 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
jkhoo
Malaysia
Many thanks for reading my post. My house have a lower plaster ceiling (about 2900mm from the floor) at the kitchen area and ceiling at the rest of the house is higher (3100mm from the floor). When i built my wall in sweethome3d utility, i spec the kitchen wall at 2900mm height and the rest of the house wall at 3100mm height. When i turn on the ceiling i notice the ceiling become uneven in the area where the wall are of different height. How do i solve this problem?
[Dec 26, 2016, 12:53:39 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
FDpaffie
Nederland
post a picture it will help to solve the problem
[Dec 26, 2016, 3:27:04 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
jkhoo
Malaysia
Hi FDpaffie,
I just post a picture in the facebook link you provided.
Here are the picture showing 2 wall with different height. How can i make the ceiling flat on the high wall while the ceiling will turn 90 degree angle as it meet the lower wall.
[Dec 27, 2016, 3:19:08 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
jkhoo
Malaysia
[Dec 27, 2016, 3:21:50 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
FDpaffie
Nederland
There are 3 ways to solve that .one is what bdfd was telling
Second one is make one wall a slopingwall ,but that gives you a celing high at one end and lower at the other end
Third option is greate a room in a room the kitchen smaller and lower..
Ps wat i mend was put a picteure on this forum. But it ok
[Dec 27, 2016, 5:33:30 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
FDpaffie
Nederland
Greate a room in a room compleet whith walls just a few milimeeters smaller
[Dec 27, 2016, 5:44:32 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
If I'm right, follow this :
Create a box with :
Elevation = 2.9 m
Width = L + 0.02 m
Depth = l + 0.02 m
Height = 3100 - 2900 => e = 0.20 m
Please let us know.
[Dec 27, 2016, 6:12:19 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Hi jkhoo
Is this is the sort of thing you are after
If it is then you can download the Stepped celing sh3d file from here . Measurements can be made to suit your project, check the room properties to see how it can be used.
Hope this helps
[Dec 27, 2016, 6:49:48 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
