Previous Thread This topic has been viewed 3731 times and has 2 replies Next Thread
Pincio
create a wall with the same height but with different starting elevation
Hello
I would like to know how to create a wall with the same height but with different starting elevation from that of the arrival, both NOT at the floor level.
Thanks for the attention
[Jan 5, 2017, 2:37:31 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: create a wall with the same height but with different starting elevation
Not sure to understand your problem. Can't you set the heights you want on walls with the Height at start and Height at end values available in the Wall modification pane?
[Jan 8, 2017, 3:33:57 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Hi Pincio
As far as i know, walls always start at 0 (floor hieght), could you use a box (which can be elevated) instead of a wall?
[Jan 8, 2017, 5:04:03 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
