italy
create sh3f library
I have a lot of objects to load in Sweet Home and I don't want to do it "one by one". Is there a program I can use to create a library sh3f ? Thank you.
Re: create sh3f library
You must have Java somewhere, installed with an installer or copied from elsewhere. The Furniture Library Editor doesn't exist as a plug-in.
If you have a HiDPI screen, install Java 10 or 11. That will fix the issue. Note that the ini file used for this purpose with Sweet Home 3D isn’t necessary with version 6.0, and I’ll be happy to know how it works for you.
Romania
If You've already import the furniture piece-by-piece (name are shown in italic), You could save all in a personal furniture library which could be loaded when needed. 1. Install the ExportToSH3F-1.0.sh3p plugin; 2. In menu: Furniture > Export imported furniture to SH3F... Note: Sometime You need to make fine adjustment in PluginFurnitureCatalog.properties file.
